1994 GMC C1500 engine running hot
BIGDADDY4U2009
Engine Mechanical problem
1994 GMC C1500 V8 Four Wheel Drive Automatic
Engine is starting to run hot and the water is being all sucked up out of the radiator and the overflow tank too.
Jul 26, 2008 at 1:44 PM
RHALL77
  • 3,361 POSTS
check and see if the cooling system is full. pressure check the system and see if there is any leaks. you may have a bad head gasket
Jul 29, 2008 at 2:55 PM
