1994 GMC C1500 4x4 in need of doc
258 MILES • V8 • 4WD • AUTOMATIC
JOEANGROD
Ive had work done on it , trans was rebuild and driveshaft was install. Now we have a sound commin from the rigth side, which is telling me that it may be the four by four or the shaft that on the rigth side. Do teeth around the axle strip to caues the turck (suv) to go foward thanks a brother in need
Jun 30, 2009 at 6:25 AM
  • 110,248 POSTS
Usually they don't, but unlikely unless they replaced the driveshaft with one that is shorter. Try disconnecting and removing the front one and drive it to see if it stops and do the same with the rear if needed.
Jul 1, 2009 at 2:14 PM
