1993 GMC C1500 Occasional Starter Grinding
147,000 MILES • V8 • 4WD • AUTOMATIC
GMC93
The starter on my truck grinds occasionally, sounds like it's not engaging the flywheel or grinding against the flywheel. I've replaced the starter and had it looked over by a starter shop. Replaced the flywheel and inserted shims but it still tends to grind ever once in a while but then its okay for a while. I've asked different mechanics, the guys at the local NAPA, and friends but nobody seems to know how to fix it. Would the starter bolts not being tight enough cause this? If so, what are the torque specs for the starter bolts?? Thanks for any advice.
Dec 27, 2008 at 12:40 PM
  • 75,988 POSTS
You're still far away from the flexplate it can be tricky shimming it-manually engage the starter drive to the flexplate now measure in between the teeths-its a trial and error thing till it shims properly-Is the starter the correct one ?
Dec 27, 2008 at 1:05 PM
