when appling brakes it shakes violently not a rotor i replaced inner and outer tie rods both sides could it be the ball joints
Aug 26, 2008 at 2:57 PM
BADBO
MEMBER
Did you check the idler arm and pitman arm. Look under the truck at them and have someone move the steering whell back and forth to see if you see any movement in either. Hope this helps To check ball joints place a flow jack next to the tire (inside)
raise it about 2 inches off the ground and with a bar
pickup on the tire and wheel to see if you see any movement. If so replace ball jpoint.
