1993 GMC C1500 low oil pressure and valve tap
1993 GMC C1500
275,000 MILES • 6 CYL • 2WD • MANUAL
MIGEL1XX1
My truck over heated the idler pully went. I t has since been replace. Now I have a serious hesitation our miss,low pressure and the valves are tapping. Last but not least the oil pressure is lower after it warms up
Jan 3, 2009 at 9:39 AM
2CARPRO JACK
  • 11,533 POSTS
sounds like you may have hurt the engine.Overheating can push a high mileage engine over the edge pretty easily. My 4.3 went 205k got it hot and it was never the same. Sometimes if theby-pass spring breaks in theoil pump it can make thevalves noisy due to lack of pressure, but it can still oil the bottom end, no promises, but that may be it. The misfire is most likely a cracked head or blown head gasket, the head castings on those are weak and tend to crack
Jan 4, 2009 at 12:22 AM
