1993 GMC C1500 coil pack: no fire
272,000 MILES • V8 • 2WD • AUTOMATIC
WHITEDEMON89
My 1500 shut down while driving and wouldn't start again.
I changed the electronic control module, the coil pack, and the ignition control module. The ignition fuse under the dash is good. I don't know what else to check. I pulled a code and it said ECM fault, but I changed the ECM and its still wont start. There is no fire between the coil pack and the distributer cap. please help.
Jun 4, 2008 at 1:44 PM
  • 75,988 POSTS
Inspect and test the distributor pick-up coil see below
https://images.2carpros.com/forum/automotive_pictures/12900_pick_up_coil_1.jpg
Jun 4, 2008 at 8:34 PM
WHITEDEMON89
Am i just looking for continuity?
Jun 5, 2008 at 4:27 AM
  • 75,988 POSTS
No.1 should read infinite and No.2 500 to 1500ohms
Jun 5, 2008 at 7:50 AM
WHITEDEMON89
No 1 was Open Line (infinite)
No 2 was 862 ohms.
Any other ideas would be great. thank you.
Jun 5, 2008 at 12:48 PM
  • 75,988 POSTS
Check for battery voltage at the pink wire on the coil-No power there and ignition fuse tested good-its coming from the ignition switch.
Jun 6, 2008 at 8:02 AM
WHITEDEMON89
pink wire is drawing the same voltage as the battery.
Jun 6, 2008 at 8:39 AM
  • 75,988 POSTS
Could be a bad ignitiion control module again or the computer is not picking up an ignition reference signal to tell the ICM to fire the coil-
Try this disconnect the coil wire from the distributor and ground it to the engine and crank it over-do you have a snapping blue spark? If so check the rotor and distributor cap-it has to make it out of there to get to the plugs. Still no spark recheck above and test the wiring from the distributor to the computer-
Jun 6, 2008 at 9:10 AM
