1993 GMC C1500 CODE 54
191,000 MILES • V8 • 2WD • AUTOMATIC
1WWALL
When I start engine I have to hold the throttle open for it to run. It runs choppy and pops back through throttle body. It has code 54 stored (low fuel pump circuit voltage) what could cause this? Thanks
Aug 28, 2009 at 6:12 AM
MERLIN2021
  • 17,250 POSTS
Code 54 will set if ECM does not see 12 volts on fuel pump signal voltage monitor during the first 2 seconds after ignition is turned on. Is this a 5.7? 5.0? The diagram below is 5.7 circuit.
https://images.2carpros.com/forum/automotive_pictures/62217_Code54_1.jpg
https://images.2carpros.com/forum/automotive_pictures/62217_54a_1.jpg
https://images.2carpros.com/forum/automotive_pictures/62217_54b_1.jpg
https://images.2carpros.com/forum/automotive_pictures/62217_54c_1.jpg
https://images.2carpros.com/forum/automotive_pictures/62217_54d_1.jpg
This chart is for both!
Aug 28, 2009 at 8:56 AM
EMERSONTASHA
thanks for the info hopefully this will help me with the problems with this truck. again thanks
Apr 24, 2012 at 12:21 PM
MERLIN2021
  • 17,250 POSTS
k
May 2, 2012 at 12:44 AM
