1993 GMC C1500 4 wheel drive
157,000 MILES • V8 • 4WD • AUTOMATIC
TICKS
When I shift to 4 wheel the front diff doesn't lock in I used an ohm meter on the sensor in the front diff and it show continiuty. checking the wires leading to the sensor I show no voltage, using a vdc meter do I insert the leads into each wire end to check or do I need to ground the black lead. Thanks
Jun 26, 2010 at 5:21 AM
HMAC300
  • 48,601 POSTS
just grounding your vom on the truck should do fine.
Jul 11, 2010 at 9:05 AM
