When I shift to 4 wheel the front diff doesn't lock in I used an ohm meter on the sensor in the front diff and it show continiuty. checking the wires leading to the sensor I show no voltage, using a vdc meter do I insert the leads into each wire end to check or do I need to ground the black lead. Thanks
Jun 26, 2010 at 5:21 AM
