Clean the MAF and. You may have a vacuum leak, get a can of spray gumout, spray the vac lines and maniflod area, when the idle changes, youve found the leak! You want the engine running and spray on the outside but do direct the stream onto the hoses, if it is a vacuum leak, the engine idle will change speed, then you have detected a leak, repair the vacuum leak and see how it runs! If no leaks found check the fuel pressure, and is your Service engine soon light on?
SPONSORED LINKS
Thursday, October 16th, 2008 AT 5:14 PM
