1992 GMC C1500 transfer case
279,000 MILES • V8 • 4WD • AUTOMATIC
SMOKEY1989
i have a 1992 gmc sierra with 305 small block 4wd and when i put it in neutral and change to neutral on the 4wd gear it makes a grinding sounds and it want lock in to 4wd anymore do you know what i would have to do to fix that
Sep 1, 2010 at 1:06 PM
  • 110,251 POSTS
If you are stopped when you shift, put it in park. That will prevent the trans from turning and the grinding
Sep 16, 2010 at 12:02 AM
