1992 GMC C1500 fuel injectors not getting gas
1992 GMC C1500
CHRISCOY
Engine Performance problem
1992 GMC C1500 V8 Two Wheel Drive Automatic
my fuel injectors are not getting gas.I checked my fuel pump its working fine. I checked my gas filter its
getting gas. Then I loosened the fitting to the Throttle Body its getting gas. it was running fine when i went to work i was idling then all of sudden it shut down it didnt make on noise like it was losing gas i tried to start it nothing it just cranks over
Dec 10, 2009 at 12:19 PM
RACEFAN966
  • 5,029 POSTS
Well there is a couple of things that I need to know and a couple of tests that you need to do. First off do you know what the fuel pressure is? I need you to unplug the injectors and check the resistance. Then you will need to pick up a noid light and check to see if there is an injector pulse. These noid lights are available at you local parts stores, you do not need to buy a kit just the one that fits your truck should be about 10 bucks. Once you have the noid light then you plug it into the injector harness and crank it do this on both injector harnesses and let me know what the light does.
Dec 11, 2009 at 10:21 AM
