1992 GMC C1500 Engine runs rough
16,000 MILES • V8 • 2WD • AUTOMATIC
DJHOPPE
Engine runs rough when cold. Sluggish. Hesitates. I put new 02 sensor, new TPG, cleaned carb.
Nov 17, 2009 at 4:07 AM
  • 75,988 POSTS
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Nov 17, 2009 at 7:56 AM
