1991 GMC C1500 overheating
1991 GMC C1500
163,153 MILES • 6 CYL • 2WD • AUTOMATIC
MANOFBRICK
my truck was losing fluid from the water pump so I replaced it. It was still overheating so I replaced the thermostat. It is still overheating. Any suggestions where to go from here?
Feb 22, 2010 at 12:57 PM
HMAC300
  • 48,601 POSTS
let the truck overheat and shut it off. place your hand on different areas of the radiator. If you feel cold or cool anywhere on the radiator it should be replaced. It should be the same temp all over. If there are also any loose fins ndcorroded, usually at edges, replace it. Replace the radiator cap when you do the radiator too.....
Feb 27, 2010 at 7:21 AM
SBARKER249
Relace radiator hoses. If they are old, they will collapse when you accelerate, restricting water flow.
Jun 4, 2010 at 10:27 AM
