1990 GMC C1500 surging and missing during exceleration
245,000 MILES • V8 • 2WD • AUTOMATIC
ISLANDIST2
i replace the egr valve, map sensor, oxygen sensor, pcv, throttle position sensor. checked all vac. line.
the code reader still shows map sensor and oxygen sensor code .. i seem to be getting worse with each thing i replace .. what am i doing wrong
Sep 1, 2009 at 10:47 AM
DR LOOT
  • 2,311 POSTS
Everything you replace sounds like fuel related problems, change your fuel filter, and then check the fuel pressure.
Sep 20, 2009 at 8:50 AM
