1990 GMC C1500 Front Pumpkin
185,000 MILES • V8 • 4WD • AUTOMATIC
LARRYBLOCK
The front axel came out of the front pumpkin. I have been told that it is as simple as a snap ring holds the axel in and it fell in. I tried practicing on a junk front pumpkin I have and for the life of me, I cannot figure out how to put this back together?? I have never had the front axel just let go like this.
May 8, 2008 at 8:08 AM
MERLIN2021
  • 17,250 POSTS
It should not do that unless the axle or the lock clip broke! So now you have the side gear out of place?
May 8, 2008 at 8:10 AM
LARRYBLOCK
[quote:a57bc5b33e="merlin2021"]It should not do that unless the axle or the lock clip broke! So now you have the side gear out of place?[/quote:a57bc5b33e]
I picked up a clip today but I am afraid that I have to split the case to fix it. That clip (c shaped) will just fall in again. Do I have to split it first? I think this is above my automotive skills!
May 9, 2008 at 11:11 AM
MERLIN2021
  • 17,250 POSTS
If the clip "fell" out, something else is wrong! Either the clip broke, the end of the axle broke, or the lock pin inside broke, dissasembly is required in all three cases!
May 9, 2008 at 10:56 PM
