1989 GMC C1500 tail lights and instrument panel lights
500,000 MILES • 6 CYL • 2WD • MANUAL
RJBREEN
for some reason when i turn the relay switch on for the lights the instrument panel and the tail lights dont turn on. i checked the fuses and they seem fine. what else could be the problem?
May 7, 2010 at 11:42 AM
HMAC300
  • 48,601 POSTS
check your grounds on the tailgihts and dash. Also make sure your battery cables are clean as well.
May 21, 2010 at 10:27 AM
