When I turn the key to Ignition On position with my signal flasher installed, the ignition seems to "flash" untill the flasher is either removed or blows, but works fine without the flasher, minus having no signals. the hazard lights work for aprox. 5 seconds when the key is off then blows the fuse. I have checked all the wiring from the firewall forward and this all happens with the lights removed. The block in which the flasher is installed seems to be the culprit but i cannot seem to trace the fault. Can anyone tell me what that block is, what it does and possibly help me fix the issue?
Jun 7, 2010 at 2:45 PM
