1989 GMC C1500
SGNGOD
Brakes problem
1989 GMC C1500 V8 Four Wheel Drive Automatic
brake lights wont come on
Nov 24, 2009 at 4:54 PM
FREEMBA
  • 1,152 POSTS
Check the brake light circuit boards (the part that the bulbs plug into). Remove the brake light housing, unplug the brake light connector. look for burned connectors and/or wires. Also check the circuit borad plug-in (female connection). If there are burned connectors replace the circuit board (sometimes you will have to get a new wire connector also---it's the plug-in with about 12 inches of wire attached --found at the dealership).
Nov 30, 2009 at 5:34 AM
