1988 GMC C1500 turn signal light lens
GEORGEKUPER
Electrical problem
1988 GMC C1500 6 cyl Four Wheel Drive Automatic lots miles
I need to change the turn signal light bulb on my GMC pickup. How do I remove the lens cover to get to the bulb. This is the left front turn signal.
Jan 22, 2009 at 6:03 AM
PEAR69
  • 1,482 POSTS
The screws that hold this cover on are called torx head screws. A torx screwdriver is needed to remove this lense. I think it is either a 10 or 15 size torx head screwdriver that is needed ( not positive). You can pruchase a cheap combo torx head screwdriver at any autoparts store.
Jan 22, 2009 at 1:21 PM
