1984 GMC C1500 trans converter vacuum switch and ignition t
1984 GMC C1500
150,000 MILES • V8 • 4WD • AUTOMATIC
ODALVO1
What is a trans conv vac switch. The emission hose from the egr tvs connects to this vac switch than it turns into an two prong connection. The ignition timing vac switch also comes from the egr tvs and
also turns into a two prong connection. There is an-
other vac switch that goes from the efe tvs that connects to another two prong connection that goes to the transmission control solenoid (TH700R4).
What is the purpose of each switch and how do we check for proper operation? I am overhauling engine and replacing vacuum emission hoses but have not found any info on the above items that might need replaceing. I have also found vacuum dagrams and electrical diagrams but no info on the above.
?lLOST WITH NO INFO.
Feb 2, 2010 at 6:14 PM
2CARPRO JACK
  • 11,533 POSTS
The vacuum switches will pass vacuum through after the TVS had reached a set temp (engine warm) you can use a remote vacuum gauge to verufy that they are working while driving down the road.The one for the trans is for the lock-up converter, it sees high vacuum(light throttle) and will lock the converter if it is in OD. You can manually test these solenoids with a 12 volt power source and a ground wire, just to see if they work
Feb 3, 2010 at 11:32 PM
