1979 GMC C1500 gauges
1979 GMC C1500
413,215 MILES • V8 • 2WD • AUTOMATIC
TRUCKER1226232896
hi i just replaced my alternator battery and starter now my gauges are flat and do not seem to work my vehicle will not start it does in fact turn over but i attempted to spray starting fluid into the carb to see if it would start and no luck please help
Aug 6, 2009 at 9:18 AM
DR LOOT
  • 2,311 POSTS
There is an accessory wire that go's down to the starter, it is located on the firewall on the left-hand side. You will see a junction box with a red wire going in and a red wire coming out, that goes down to the starter and it has a usable link, that is your power to all your accessories, including your ignition, and gauges.
Sep 20, 2009 at 9:07 AM
