What does Code P1441 mean engine bogs down ?
209,000 MILES • 3.1L • V6 • 2WD • AUTOMATIC
SAMGREW
  • 59 POSTS
Car skipping. codes P0336, P0141, and P1441. Have changed crank position sensor. What does P1441 mean? engine to bog down when acceleration
Feb 24, 2025 at 11:38 PM
  • 55,710 POSTS
So this code is stored when the purge solenoid gets stuck open, you can confirm the issue when it is removed, and you can blow through it telling you it is bad.
P1441 - EVAP System Flow During Non-Purge Condition
Here is the location of the purge solenoid so you can check it out, be sure to clear the codes once the repairs are completed. Check out the images (below). Please let us know what happens.
Feb 25, 2025 at 3:14 AM
SAMGREW
  • 59 POSTS
Will this cause the engine to bog down when acceleration?
Apr 3, 2025 at 4:45 AM
SAMGREW
  • 59 POSTS
Changed crank position sensor. Now getting code p0300 and p0336.
Apr 3, 2025 at 4:47 AM
SAMGREW
  • 59 POSTS
New problem. Transmission will not shift until you let of accelerator pedal.
Apr 3, 2025 at 4:50 AM
  • 55,710 POSTS
This can happen when the catalytic converter is clogged, here is a guide to help detect the problem:
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
P0300 - Random/Multiple Cylinder Misfire Detected
P0336 - Crankshaft Position Sensor "A" Circuit Range/Performance
So, the crankshaft sensor might be defective, can I ask which brand you used? Please go over this guide and get back to us.
Apr 4, 2025 at 2:48 AM
