Glove box removal
126,000 MILES • 3.6L • 6 CYL • 2WD • AUTOMATIC
LUKE LUGNORE
  • 26 POSTS
How do I remove the glove box?
Oct 24, 2017 at 7:59 AM
STEVE W.
  • 15,405 POSTS
Open the door on the box. There are two tabs in the rear that snap free but they are a bear to get free because you need to almost close the door while you push the tab in and twist it so you can pull it into the box. Then the door can drop down so you can remove the lift arm and door pins.
Oct 25, 2017 at 3:58 AM
