Grinding/whining sound when driving
170,000 MILES • 4.6L • V8 • 4WD • AUTOMATIC
CHADWICK ALDRIDGE
There's a grinding/whining sound when I start to drive, I have video.
Mar 20, 2022 at 12:21 PM
Thanks for attaching a video but there may have been an issue with attaching it because we only got a couple seconds, but I didn't hear the noise.
However, is this noise only when the vehicle is moving?
If that is the case the most likely issue is a bearing, but we need to run through these guides to see if any of these issues match up with what you are seeing:
https://www.2carpros.com/articles/vehicle-grinding-noise
https://www.2carpros.com/articles/car-howling-noise
Also, the next likely thing would be a tire issue, so we need to check the tires and find out if they are cupped or worn improperly.
I am attaching the chart below that will help with checking the tires.
Please run through this and let us know what you find. Also, if you can try and reattach the video that will definitely help.
Thanks
Mar 21, 2022 at 10:23 AM
