How to remove the ignition cylinder?
10,000 MILES • 2WD • MANUAL
COWBOYUP1995
I tried to get it out but there is no button on the top or bottom to push and we drilled it and everything nothing is working what do i do?
Feb 25, 2022 at 1:28 PM
This ignition does not appear to have a button to release it. It appears you have to twist this one out and you do that by using a punch to put a groove in it and a flat head screwdriver to turn it and remove it.
I am attaching the info below but if the ignition switch is stuck, here is a guide that may help. This may be too late for you if you have already drilled it, but it may have good info that is helpful:
https://www.2carpros.com/articles/ignition-switch-wont-turn-stuck
I am attaching the info below from the manual on this that talks about this.
Unfortunately, the manual doesn't have specific instructions that contain a lot of detail, but it does explain what I talked about above.
Please run through this and let us know what you find. Thanks
Feb 27, 2022 at 9:43 AM
