Engine is overheating when you drive it on the highway?
100,000 MILES • 1.7L • 4 CYL • 2WD • AUTOMATIC
RANDY1955
  • 71 POSTS
The engine is overheated when you drive it on the highway it is fine but when you get off the highway into town it will get hot fast. It has a brand-new radiator the fans are working the motor only has maybe 20,000 at the most.
May 21, 2023 at 9:01 AM
  • 55,532 POSTS
The first thing I would do is replace the thermostat and check for a blown head gasket. Here are two guides to help us with instructions on how to change the thermostat out in the images below:
and
https://www.2carpros.com/articles/engine-overheating-or-running-hot
May 22, 2023 at 3:16 AM
RANDY1955
  • 71 POSTS
This car has 150lbs compression in each cylinder the engine runs great aside from getting Hot. I pressure tested it with the dye and no leaks. Okay, the other day I wanted to see if problem was occurring I have been driving it around town only so I drove maybe 15 miles away on the highway and as soon as I got into town driving it got hot and it does not go up slow it goes to hot just like that it has a new radiator and has a new thermostat. So, figure that one out.
May 22, 2023 at 4:39 PM
RANDY1955
  • 71 POSTS
This car has 150lbs compression in each cylinder the engine runs great aside from getting Hot.I pressure tested it with the dye and no leaks. Ok the other day I wanted to see if problem was occuring I have been driving it around town only so I drove maybe 15 miles away on the highway and as soon as I got into town driving it got hot and it does.not go up slow it goes to hot just like that it has a new radiator and has a new thermostat. So figure that one out
  • 55,532 POSTS
Did you chemical test the cooling system as in the guide? Also does it force coolant into the coolant reservoir? I also have seen the water pump impeller come loose in the water pump which can cause the problem you are having.
May 23, 2023 at 4:39 AM
RANDY1955
  • 71 POSTS
Yes, it does force coolant into the reservoir.
May 23, 2023 at 4:43 AM
  • 55,532 POSTS
It sounds like the head gasket is blown or you have a bad radiator cap.
This guide can help:
https://www.2carpros.com/articles/why-coolant-is-forced-into-the-reservoir
Please go over this guide and get back to us.
May 25, 2023 at 3:20 AM
