shuts off on the road and will not start
207,000 MILES • 7.4L • 6 CYL • 4WD • AUTOMATIC
CONSTANCE GRAVESTOCK
Getting error codes for crank shaft position sensor. We have replaced it three times. The last time we bought an expensive AC Delco from the GMC dealer. That went thirty miles and and failed just like the others. quits running on the road and will not start.
May 21, 2017 at 2:56 PM
HMAC300
  • 48,601 POSTS
have you done a wiggle test on connector that may be the problem. also, is crank sensor the right distance away sometimes that will do it.
May 22, 2017 at 12:26 AM
