Code PO420
2006 HONDA CIVIC HYBRID
160,000 MILES • 4 CYL • AUTOMATIC
TORNADO33
When first starting up it sounds like a tiger growling. Sometimes the rpm's race.
Feb 12, 2019 at 8:38 AM
  • 110,240 POSTS
The code you have is related to the catalytic converter. It indicates catalyst efficiency below threshold. Anytime I have had this code, the catalytic converter is bad. Since you hear a strange noise upon start up, have a helper start the engine while you listen near the converter to see if that is where the sound is coming from. It may be partially plugged.
Take a look through this link:
https://www.2carpros.com/articles/bad-catalytic-converter-symptoms
Here is a link showing how to check one:
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
https://www.2carpros.com/articles/catalytic-converter-replacement
I attached a picture showing the converter (Pic 1). It is right off the exhaust manifold. Check for the noise coming from there. If you determine the converter is the problem, here are the directions for removing and replacing it.
THREE WAY CATALYTIC CONVERTER REMOVAL/INSTALLATION
Three Way Catalytic Converter Removal and Installation
Picture 2
Removal
1. Remove the engine cover.
2. Remove the IMA power cable clamps (A) and the bolt (B).
Picture 3
3. Remove the cowl cover.
4. Disconnect the air fuel ratio (A/F) sensor connector (A) and the secondary heated oxygen sensor (HO2S) connector (B).
Picture 4
5. Remove the A/F sensor.
Picture 5
6. Remove the chamber cover.
Pic 6
7. Raise the vehicle on the hoist to full height.
8. Remove the front wheels.
9. Remove the engine undercover and the splash shield.
10. Remove the under-floor TWC.
Picture 7
11. Remove the right side drive shaft.
NOTE: Coat all precision finished surfaces with clean engine oil. Tie plastic bags over the drive shaft ends.
12. Remove the intermediate shaft.
13. Remove the warm up three way catalytic converter (WU-TWC) bracket (A), then remove the WU-TWC (B).
Picture 8
Installation
1. Install a new gasket (A), then install the WU-TWC (B) and tighten the bolts/nuts in a crisscross pattern in two or three steps.
Picture 9
2. Install the WU-TWC bracket (C).
3. Install the intermediate shaft.
4. Install the right side drive shaft.
5. Install the under-floor TWC (A); use new bolts (B), new gaskets (C), and new self-locking nuts (D).
Picture 10
6. Install the engine undercover and the splash shield.
7. Install the front wheels.
8. Lower the vehicle on the hoist.
9. Install the chamber cover.
Picture 11
10. Install the A/F sensor.
Picture 12
11. Connect the A/F sensor connector (A) and the H02S sensor connector (B).
Picture 13
12. Install the cowl cover.
13. Install the IMA power cable clamps (A) and the bolt (B).
Picture 14
14. Install the engine cover.
______________________________________________________
Let me know if this helps or if you have other questions
Feb 12, 2019 at 11:55 AM
