Getting check engine code P0753, says "Shift Solenoid A Electrical"
137,000 MILES • 5.9L • V8 • 4WD • AUTOMATIC
DAVE1984
I need to find out what needs to be changed or replaced to fix this problem. The symptoms are that the vehicle does not shift AT ALL. It goes in reverse fine with full power,but once I put it in Drive, no dice. Not a single shift. Car has brand new converter and fluids.
Mar 2, 2014 at 10:57 AM
  • 110,251 POSTS
That deals with a shift solenoid A
Mar 5, 2014 at 2:38 AM
DAVE1984
I know there's more than 1 solenoid..where is solenoid A located?
Mar 5, 2014 at 4:31 AM
  • 110,251 POSTS
They are in the transmission. I believe yours will be mounted on the valve body.
Mar 6, 2014 at 12:28 AM
