Getting bad gas mileage
192,463 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
GIGISULAMANIDZE1
  • 88 POSTS
Hello, my car getting bad gas mileage about 13-14 mpg.
new: spark plugs , coils, filters, fuel filter, no check engine light. (car was getting about 17-18 mpg)
shrift1 (%) -0.8
longft1(%) -10.9
shrift2(%) -3.1
longft2(%) -8.6
rpm 756
sparkdv(C) 10
Jan 24, 2019 at 1:50 AM
Good morning,
There are so many factors for fuel mileage.
Driving habits are the most important.
Tires. The tires need to be properly inflated and check regularly.
Alignment. Front end alignment is critical for the car rolling free.
Brakes. Make sure they are not hanging up. Have them checked regularly.
Filters. Make sure the air and fuel filters are changed every year.
Transmission. Make sure the shift points have not changed.
Jan 24, 2019 at 2:56 AM
GIGISULAMANIDZE1
  • 88 POSTS
i have had this car about eleven years. every thing is changed always at time, but now it has bad mileage, new spark plugs coils is installed, filters. only code sometimes show is p0705.no check engine overdrive light. car drives good but getting bad mileage. tires are balanced, alignment is done. i saw that longft and srift is always in negative, car sometimes idle.
shrift1 (%) -0.8
longft1(%) -10.9
shrift2(%) -3.1
longft2(%) -8.6
Jan 24, 2019 at 3:03 AM
The long terms could be from either the engine running a little rich, possibly from an air filter, or the sensors are worn out.
the 705 is for the transmission range sensor not reading correctly. That would have nothing to do with the mileage issue.
Timing chains are the other thought. Have you ever had them replaced?
Jan 24, 2019 at 3:19 AM
GIGISULAMANIDZE1
  • 88 POSTS
No, never. which sensor may be worn out?
Jan 24, 2019 at 3:23 AM
Oxygen sensors.
The timing chain controls valve timing. If the chains are worn, that timing will change and you will get less mileage.
Jan 24, 2019 at 3:26 AM
GIGISULAMANIDZE1
  • 88 POSTS
if timing chains are bad it should have sound? engine working fine no bad sounds
Jan 24, 2019 at 3:33 AM
no, not at all. They slack off and you cannot hear that at all.
Jan 24, 2019 at 4:02 AM
GIGISULAMANIDZE1
  • 88 POSTS
thank for answer. how can i check if chain went bad?
Jan 24, 2019 at 4:03 AM
You would need to do a compression test and compare the readings to new.
Then the cover for the chains should be removed to inspect. That is a big job and if you are going to go that far, then you might as well replace it.
Jan 24, 2019 at 4:10 AM
GIGISULAMANIDZE1
  • 88 POSTS
Our compression test was done about three month ago mechanic sad that compression was good (like new one).
Jan 24, 2019 at 4:12 AM
Okay, that was three3 months ago and this is now and you have different mileage.
Jan 24, 2019 at 4:15 AM
GIGISULAMANIDZE1
  • 88 POSTS
mileage from the test changed with 200 miles, i will check that again.
Jan 24, 2019 at 4:16 AM
Okay, sounds like a plan.
Jan 24, 2019 at 4:25 AM
  • 55,743 POSTS
I have seen MAF cause this problem even though the numbers are kind of where they should be the sensor shows less air than what is entering the engine. I would replace it will new. here is a guide and diagrams below:
https://www.2carpros.com/articles/how-to-replace-a-mass-air-flow-sensor-maf
Jan 25, 2019 at 5:44 AM
GIGISULAMANIDZE1
  • 88 POSTS
installed new maf sensor, also compression test was done "perfect numbers"
now showing
Shrift1 (%) -7.8
longft1(%) -13.3
shrift2(%) -7.8
longft2(%) -8.6
maybe air leack ? car drives good
Feb 2, 2019 at 2:28 AM
The long term trims indicate it is running rich. They should be much closer to 0.
Have you had the injectors professionally cleaned? Additives have no effect on cleaning.
Feb 2, 2019 at 6:28 AM
GIGISULAMANIDZE1
  • 88 POSTS
Update:
injectors professionally cleaned, new air intake gaskets,car runs better. now showing this :
Shrift1 (%) -2.8
longft1(%) -5.5
shrift2(%) -3.4
longft2(%) -5.5
Feb 16, 2019 at 2:26 AM
Much better.
Is the light off now?
Feb 16, 2019 at 3:35 AM
GIGISULAMANIDZE1
  • 88 POSTS
check engine light was off, better gas mileage now . next week i will try smoke test.
Feb 16, 2019 at 3:39 AM
Sounds good.
Feb 16, 2019 at 3:41 AM
GIGISULAMANIDZE1
  • 88 POSTS
Update: no air leaks car drives good
cold start
Shrift1 (%) -2.8
longft1(%) -5.5
shrift2(%) -3.4
longft2(%) -5.5
but when worms up
Shrift1 (%) -3.8
longft1(%) -8.5
shrift2(%) -4.4
longft2(%) -8.5
Also what is RPMDSD (Desired Idle Speed) for Ford Escape 2003 3.0? Mine shows 745-780 is it normal? Aand also when i turned of IAC sensor car was running much better about 650-700 (but some times was misfiring) getting better gas mileage now.
Feb 26, 2019 at 3:04 AM
Got it.
Okay, you need to adjust the base idle to 500 RPM. There is a base idle screw on the throttle body and after setting the idle to 500, plug in the IAC and the idle should return to normal.
Feb 26, 2019 at 3:34 AM
GIGISULAMANIDZE1
  • 88 POSTS
Can you show photo where is that screw?
Feb 26, 2019 at 3:40 AM
Okay, I cannot see the screw in any drawing. You need to look where the accelerator cable attaches to the throttle body. It will be there.
Feb 26, 2019 at 4:47 AM
GIGISULAMANIDZE1
  • 88 POSTS
update car runs smooth
shrift1 (%) _0.8
longft1(%) _ 0
shrift2(%) -_0.8
longft2(%) -0
MAX
shrift1 (%) 7.8
longft1(%) -0
shrift2(%) -5.5
longft2(%) -0
getting 26 highway
19 city
Mar 5, 2019 at 12:10 AM
Is the check engine light on or off?
Mar 5, 2019 at 2:18 AM
GIGISULAMANIDZE1
  • 88 POSTS
Check engine light was off all time. getting better fuel mileage than last three years.
Mar 5, 2019 at 3:54 AM
Good deal.
Mar 5, 2019 at 5:16 AM
GIGISULAMANIDZE1
  • 88 POSTS
Hello, update:
shrift1 (%) 28
longft1(%) 2.3
shrift2(%) 32
longft2(%) 2.3
car runs bad. :/ only thing that i changed today is vacuum break booster (bought from junk yard) it's can be bad vacuum break booster ? car was running good when i changed vacuum break booster than car was running bad and rpm are high.
Mar 17, 2019 at 4:16 AM
Junk yard parts are never a good idea.
Yes, it sounds like it is bad. I would get a rebuilt one.
Mar 17, 2019 at 8:39 AM
