GETTING ACCESS TO THE FUEL PRESSURE TEST PORT
237,000 MILES • 3.3L • 6 CYL • FWD • AUTOMATIC
SAYEEDFAMILY.ORG
  • 19 POSTS
How do you obtain access to the fuel pressure test port for a Dodge Grand Caravan 2002, 3.3 litre, V6?
Feb 20, 2016 at 1:52 PM
WRENCHTECH
  • 20,758 POSTS
The 3.3L does not have a test port. This requires you to put a T in the line and put the gauge on the system this way.
Below you will find the process from the manual on how to do this test because it is not the easiest one due to not having the test port.
Please run through this info and let us know what questions you have. Thanks
Feb 20, 2016 at 9:27 PM
SAYEEDFAMILY.ORG
  • 19 POSTS
Thank you very much for the information.
I have the original printed manual from Daimler Chrysler for the Dodge Grand Caravan 2002, 3.3 litre, V6. This manual does not breathe a word about the fuel pressure test port. None at all.
However, after I got your diagram, I put my hand behind the engine and felt a rectangular or square object near the rear intake manifold which appeared to be similar to the one shown in the diagram. Is it the protective cap for the test port? If so, is it to be removed by unscrewing it? I tried to unscrew it with my hand but I could not. Will a wrench be necessary? I do not want to break it.
Please advise. I await your response.
Regards,
Kabeer Sayeed
Feb 21, 2016 at 8:26 AM
WRENCHTECH
  • 20,758 POSTS
That diagram shows it in the front of the engine, not the back. It should be right in front of you standing in front of the truck.
Feb 21, 2016 at 8:29 AM
SAYEEDFAMILY.ORG
  • 19 POSTS
Thank you very much for your prompt response.
I looked in the front at first. I could not find anything that resembles the rectangular object shown in your diagram. That is why I reached into the back over the plenum and felt something rectangular in the back.
Do I have to remove anything to expose the test port?
I will double check and get back to you as soon as possible.
Regards.
Kabeer Sayeed
Feb 21, 2016 at 8:38 AM
WRENCHTECH
  • 20,758 POSTS
The port should have a round plastic cap threaded on likje this one although this is not from your vehicle.
Feb 21, 2016 at 8:44 AM
SAYEEDFAMILY.ORG
  • 19 POSTS
Once again, thank you for your response.
As mentioned earlier, I looked long, hard , and as carefully as possible at the front of the engine to see if anything resembling the a test port (also referred to as "Schrader valve" in some circles). I could not find any such test port. Also, there was nothing resembling the port that you recently sent to me.
Incidentally, according the Daimler Chrysler manual for the Dodge Grand Caravan 2002, 3.3 litre, V6, there are two intake manifolds, namely, the upper and the lower manifolds. Both these manifolds are right in the middle of V6 engine block and cylinder heads.
Feb 21, 2016 at 1:23 PM
SAYEEDFAMILY.ORG
  • 19 POSTS
I am sorry that the last message was incomplete. I am continuing it below.
In a previous message of yours, you referred to the vehicle in question as a "truck". I am wondering if you and I are talking about the same vehicle. As already mentioned earlier, the vehicle I am talking about is a mini-van.
Furthermore, if there was a test port, I wonder why the original Daimler Chrysler manual has not said a word about it. Their engineers and technical writers could not be so negligent.
Perhaps, it might help you to know that I am trying to solve a vehicle stalling problem. The vehicle runs for about 15 minutes and then stops. If after about 30 minutes, it is started again, it runs for another 15 minutes and then stops and so on. I am wondering if it is a fuel pump problem because I just replaced the fuel filter with a brand new one costing about 45.00 $. There was no improvement. I would like to confirm that the fuel pump is the problem or if there is a much deeper problem by testing the fuel pressure before I spend about 300.00 $ for a brand new pump and lot of time replacing it. I don't want it ending up as a wild goose chase
I hope I have given you some food for thought and look forward to your response.
Regards.
Kabeer Sayeed
Feb 21, 2016 at 1:46 PM
WRENCHTECH
  • 20,758 POSTS
I found a different picture. See if this helps, https://www.2carpros.com/images/external/97325203.jpg.gif
Feb 21, 2016 at 6:01 PM
SAYEEDFAMILY.ORG
  • 19 POSTS
Thanks again for your response.
I checked the mini-van for a fuel rail rest port similar to the one shown in your last diagram. I looked near the ignition coil (this is similar to the one in your diagram) but no test port was visible.
However, there is a Power Steering Pump Reservoir above the Ignition Coil in the minivan which is not shown in your diagram. This Reservoir may be obscuring the fuel rail rest port. I am wondering if removing the Reservoir will expose the test port. What do you think?
By the way, does the diagram that you sent me depict exactly the same engine as the one for Dodge Grand Caravan 2002, 3.3 litre, V6 engine? Kindly clarify.
Regards.
Kabeer Sayeed
Feb 22, 2016 at 8:17 AM
WRENCHTECH
  • 20,758 POSTS
Yes, it does but there are 2 different 3.3 engines. What is your 8th digit of the VIN#?
Feb 22, 2016 at 8:19 AM
SAYEEDFAMILY.ORG
  • 19 POSTS
Thanks very much for your very prompt response.
The following is the VIN of the mini-van that we have been discussing:
2B4GP44R32R601774
The 8th alphanumeric symbol appears to be "R".
I hope this helps.
I look forward to hearing from you.
Regards.
Kabeer Sayeed
Feb 22, 2016 at 8:26 AM
WRENCHTECH
  • 20,758 POSTS
That was the correct picture for your vehicle and engine. The fuel rail runs up the middle of the manifold with the injectors leading off of it. IF it has a service port, and it may not. it will be on that rail.
Feb 22, 2016 at 8:34 AM
SAYEEDFAMILY.ORG
  • 19 POSTS
Thank you for your response.
I found something that looked like the "Fuel Rail Test Port" that was shown in the last diagram that you sent me. I had to remove the power steering reservoir and it was behind it. It is rather strange that the designers of the vehicle made it so very difficult to obtain access to a simple test port! The design was as bad as the design of the fuel tank and filter where I had to remove the tank to replace the fuel filter which could have been, quite easily, kept in the engine compartment as was the case with other vehicles that I have owned.
However, the "Fuel Rail Test Port" has a peculiar cap on top of it. When I tried to unscrew this cap, it just kept on rotating and did not come off. On examination of the cap, it appeared to be secured to the port in a rather odd way which was quite unlike the usual threaded caps on Schrader valves. It had metal tabs below it which seemed to secure it to the test port.
Before I try to remove it using some other method and perhaps cause damage to the cap and the port, I would like your expert opinion on the best way to get it off.
I look forward to your response.
Regards.
Kabeer Sayeed
Mar 8, 2016 at 10:22 AM
WRENCHTECH
  • 20,758 POSTS
I doubt you are looking at the test port.That description doesn't sound like the test port. The reason the filter is in the tank is because it is not supposed to be changed. It;s self cleaning.
Maybe you could take a picture of it and post it here.
Mar 8, 2016 at 10:27 AM
SAYEEDFAMILY.ORG
  • 19 POSTS
Thanks for your response.
I have checked and DOUBLE CHECKED for any object that looks like a test port on the fuel rail close to the induction coil which looks similar to the "Fuel Rail Test Port" shown on the last diagram that you sent me. There is NOTHING other than the object that I described to you in my last posting and it is located in EXACTLY the same location as the object that was shown to be the "Fuel Rail Test Port" in your diagram.
The object looks like a miniature top hat and it is attached to and covering a projection with an opening on the fuel rail. It appears to be some form of a dust cover. It is attached to the projection by about 4 tabs at the bottom of the hat. It appears possible to open the tabs and remove the hat like object. It is made of aluminium or other non-ferrous metal since a magnet does not get attracted to it. It is shiny metallic white in colour. It is smooth on the outside and has no knurling (to provide a grip) on it unlike the usual dust covers for Schrader valves.
Its dimensions are approximately as follows:
Diameter of the top of the hat: 12 to 14 millimetres (mm)
Diameter of the rim of the hat: 20 mm
Total height of the hat including rim: 12 to 14 mm.
I hope the above gives you an idea of what the object looks like. I will try to send you a photograph or a diagram as soon as possible. Meanwhile, the above information may provide some food for thought.
I hope to hear from you soon.
Regards.
Kabeer Sayeed
Mar 9, 2016 at 4:33 AM
WRENCHTECH
  • 20,758 POSTS
I just can't do anything for you here. I asked you for a picture of what you are looking at and we don't have that. Your description just doesn't tell me what you are looking at.
Mar 9, 2016 at 4:58 AM
SAYEEDFAMILY.ORG
  • 19 POSTS
Here is the image of what seems to be the "Fuel Pressure Test Port". You will notice that it is sitting on top of the Fuel Rail. I had to remove the Power Steering Fluid Reservoir to expose it to take a picture of it. You will notice that it is exactly as described by me in my previous message. Note that the top hat like cover is attached by clips to a projection on top of the fuel rail.
I feel that this has to be the fuel test port because there is nothing else on the vehicle that could be a fuel pressure test port.
Regards.
K. A. Sayeed
Apr 7, 2016 at 10:24 PM
WRENCHTECH
  • 20,758 POSTS
No, I have never seen a test port look like that.
Apr 7, 2016 at 11:02 PM
SAYEEDFAMILY.ORG
  • 19 POSTS
I take note of your response. We live and learn.
Can you confirm that that it is indeed the fuel pressure test port?
Regards.
Kabeer Sayeed
Apr 12, 2016 at 6:01 AM
SATURNTECH9
  • 30,868 POSTS
That is the fuel pressure regulator that you found which is on the fuel rail where the port should be.Follow down from where the pressure regulator is looking for the test port.
Apr 23, 2016 at 3:16 AM
SAYEEDFAMILY.ORG
  • 19 POSTS
As I have mentioned in the preceding correspondence, I have the ORIGINAL manual from
Daimler Chrysler for the vehicle in question and there is no indication of any fuel pressure test port or fuel pressure regulator on the fuel rail.The object in the image that I have sent earlier is not even shown as part of the fuel rail in the manual and there is absolutely no discussion of any fuel pressure test port in the manual.
I have searched long and hard for a fuel pressure test port on the vehicle in question and have never found one. Therefore, in order to avoid going off on a wild goose chase, can you send me an image of the fuel pressure test port for the vehicle in question so that I know where to find it.
Regards
Kabeer Sayeed
Apr 24, 2016 at 5:38 AM
  • 55,865 POSTS
Some models did not have a test port you must tap in the fuel line itself.
Apr 24, 2016 at 6:32 AM
SATURNTECH9
  • 30,868 POSTS
I just worked on a 2000 3.3L engine today it didn't have a test port.See picture I attached where my finger is pointing.That's where you will have to tap in to do the fuel pressure test.
Apr 24, 2016 at 11:18 AM
SAYEEDFAMILY.ORG
  • 19 POSTS
Where is the fuel pressure test port for a Dodge Grand Caravan 2002, 3.3 litre, V6?
Mar 27, 2019 at 5:54 AM (Merged)
WRENCHTECH
  • 20,758 POSTS
Duplicated question ........................... flagged for removal
