getting ABS codes 22 and 21
300,000 MILES
QEWANI
  • 32 POSTS
I am getting ABS and VSC signs on. getting ABS codes 21 and 22. Please help me!
Mar 23, 2018 at 5:07 PM
KHLOW2008
  • 41,812 POSTS
Code 21 is right front ABS solenoid circuit.
Code 22 is left front ABS solenoid circuit.
Check the ABS actuator (control unit) wire harness for cleanliness and tight connections. Such problems are usually due to a faulty control unit if the wiring circuits are good.
Mar 25, 2018 at 11:54 PM
QEWANI
  • 32 POSTS
connections wire checked on actuator which all connected well. i have changed the front ABS sensors with used one, and cleared the code, but again code reappeared with same codes 21 and 22.
Mar 26, 2018 at 12:07 AM
KHLOW2008
  • 41,812 POSTS
Sensors seldom fails in tandem and the most likely cause would be the control unit, meaning the ABS module needs to be replaced.
Mar 26, 2018 at 7:05 PM
QEWANI
  • 32 POSTS
shall i go ahead with changing the ABS ECU, any diagnosis process which i can do before going with that option please?
After clearing code it appeared again, but this time tried to read ABS code, did not get any ABS blinks it just show ABS light on without any blinks, also in VSC it shows code 43.
Please guide.
Mar 27, 2018 at 11:48 PM
KHLOW2008
  • 41,812 POSTS
Before replacing the control unit, you need to be sure that the sensors and its wiring are not the ones at fault. You mentioned testing with used sensors, how sure are you that they are good?
If you read the live data, you should be able to understand if the sensors are working. Lift up front of vehicle and get somebody to turn each wheel while you read the live data of the sensors.
Mar 29, 2018 at 7:43 PM
QEWANI
  • 32 POSTS
i dont have special reading tool to read the abs sensor data, but can i read sensor voltage with milimeter while turning the wheel by hand and what should be the proper reading out for voltage with turning wheel
Mar 29, 2018 at 11:43 PM
KHLOW2008
  • 41,812 POSTS
Sorry for the delay in getting back to you. I have delved deeper into this and here are the testing procedures. It is the solenoids and not the sensors that are causing the problem. Go through the testing procedures and see what comes up.
DTC C0226/21: RIGHT FRONT ABS SOLENOID CIRCUIT, DTC C0236/22: LEFT FRONT ABS SOLENOID CIRCUIT, DTC C0246/23: RIGHT REAR ABS SOLENOID CIRCUIT OR DTC C0256/24: LEFT REAR ABS SOLENOID CIRCUIT
CAUTION: If Anti-Lock Brake System/Traction Control/Vehicle Skid Control Electronic Control Unit (ABS/TRAC/VSC ECU) replacement is necessary during testing, always ensure ABS/TRAC/VSC ECU connectors and ground circuit are okay. If either is suspect, repair and repeat testing to confirm ABS/TRAC/VSC ECU malfunction.
Circuit Description
ABS solenoid turns on when signal is received from ABS/TRAC/VSC ECU. Solenoid controls fluid pressure acting on brake calipers. DTC is set when system is operating and ABS/TRAC/VSC ECU detects an open or short circuit in ABS solenoid circuit for .05 seconds or more. If a fault occurs in ABS solenoid circuit, ABS/TRAC/VSC ECU performs a fail safe function, turning off current to ABS solenoid relay and prohibiting ABS, TRAC and VSC. Possible causes are:
ABS/TRAC/VSC Actuator
Open Or Short Circuit
ABS/TRAC/VSC ECU
Diagnosis & Repair
Remove air cleaner and battery clamp cover to gain access to ABS/TRAC/VSC actuator. Disconnect ABS/TRAC/VSC actuator connectors. Check resistance between terminal No. 4 at ABS/TRAC/VSC actuator A34 connector and specified terminals at ABS/TRAC/VSC actuator A36 connector. See ABS SOLENOID RESISTANCE CHECK table. See Fig 1. If resistance is as specified, go to next step. If resistance is not as specified, replace ABS/TRAC/VSC actuator.
ABS/TRAC/VSC Actuator A36 Connector Terminal No. Ohms
2 8-10
3 3-6
4 8-10
5 8-10
6 3-6
7 3-6
10 3-6
12 8-10
(1) Measure resistance between terminal No. 4 at ABS/TRAC/VSC actuator A34 connector and connector A36 terminals listed. See Fig 1.
Fig 1: Testing ABS Solenoid Resistance At ABS/TRAC/VSC Actuator
G98G13009
Courtesy of TOYOTA MOTOR SALES, U.S.A., INC.
Disconnect ABS/TRAC/VSC ECU harness connectors. ABS/TRAC/VSC ECU is located behind right kick panel. See Figure. Check for open or short in ABS solenoid circuits between ABS/TRAC/VSC actuator and ABS/TRAC/VSC ECU. See ABS SOLENOID CIRCUIT CHECK table. See Figure and Fig 1 . Repair wiring as necessary. If wiring is okay, clear DTCs. See CLEARING DIAGNOSTIC TROUBLE CODES under DIAGNOSIS & TESTING. Test drive vehicle and retrieve codes. See RETRIEVING DIAGNOSTIC TROUBLE CODES under DIAGNOSIS & TESTING. If code is still present, replace ABS/TRAC/VSC ECU.
ABS/TRAC/VSC Actuator A36 Connector Terminal No. Wire Color ABS/TRAC/VSC ECU Connector (Terminal No.)
2 Blue/Red A38 (21)
3 Blue A41 (8)
4 Yellow/Black A41 (16)
5 Violet/White A41 (7)
6 Yellow A38 (9)
7 Light Green/Red A38 (7)
10 Blue/Black A41 (1)
12 Red A38 (21)
Mar 30, 2018 at 12:32 AM
