Getting a drag start in the mornings or whenever the engine is cool
95,000 MILES • 4 CYL • FWD • AUTOMATIC
GURU KOOBAIR
When engine is hot or warm,it starts perfectly n works fine.The problem is when it is cool....I bought new battery and I even change the starter motor but the problem still remain.
Apr 3, 2016 at 8:57 AM
HMAC300
  • 48,601 POSTS
check for corrosion on cable and clean battery terminal ends. same with ground end on engine.
Apr 4, 2016 at 12:18 AM
GURU KOOBAIR
My mechanic checked the cables,cleaned both battery terminal ends and the ground end on the engine and I'm still getting the drag start when the engine is cool.
Apr 4, 2016 at 3:23 AM
HMAC300
  • 48,601 POSTS
check starter for a draw and is battery the correct size for your car. the starter may be drawing to much power when cold.
Apr 4, 2016 at 5:02 AM
GURU KOOBAIR
I had an auto electrician check the starter n batteries....No problem there....Could it be a mechanical problem of the engine ,that puts more pressure on the starter when engine is cool?
Apr 5, 2016 at 8:27 PM
HMAC300
  • 48,601 POSTS
I kind of doubt that if anything i''d suspect a bad cable or poor ground to engine or starter.
Apr 6, 2016 at 12:06 AM
GURU KOOBAIR
We finally found the problem.....A bad capacitor in the electronic control box...Thanks for your help and guidance ....God bless !!!
Apr 6, 2016 at 8:49 PM
