Transmission gets stuck in gear
150,000 MILES • 1.4L • MANUAL
GROUVEL39
Transmission gets stuck in gears and doesn't come out of gear unless you turn the engine off, sometimes that doesn't work. Also, there is a noise that I haven't heard before. car struggles to drive up hills, also car loses power.
Feb 17, 2022 at 2:59 AM
While there could be other things this is almost surely a failing clutch.
What happens is when you press the clutch, and the pressure plate does not fully disengage the clutch then it is hard to shift, and you will lose power because the clutch is slipping.
Here are a couple of guides that will help with this:
https://www.2carpros.com/articles/clutch-doesnt-work-sometimes-or-not-at-all
https://www.2carpros.com/articles/clutch-symptoms
While we don't have a manual on this vehicle, we do have a couple guides that will help with replacing this:
https://www.2carpros.com/articles/throw-out-bearing-replacement
https://www.2carpros.com/articles/how-to-replace-a-clutch
If it were me, I would inspect and replace the clutch as this is the likely issue with this. Thanks
Feb 18, 2022 at 11:20 AM
