Overheating?
92,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
EDY ESTRADA
My car overheats.
Jul 11, 2022 at 8:13 PM
SQM
  • 6,383 POSTS
An engine can overheat due to a number of reasons.
It could be as simple as being low on coolant. It can also be due to a stuck closed thermostat, bad water pump, faulty radiator, inoperative cooling fans. It can also overheat due to having a clog in the cooling system or contaminated coolant.
Take a look at this helpful guide. It can help you determine what could be the culprit.
https://www.2carpros.com/articles/engine-overheating-or-running-hot
Let me know what you find or if you have any questions.
Jul 12, 2022 at 1:14 AM
