geo tracker check engine light
GSXR8711
95 geo tracker 160000 miles, 1.6L,
check engine light just came on,went to check the codes,with a snap-on code checker, and it said there was a 6 pin connector , by the left strut tower at the firewall that needed 2 pins shorted, i cant find it, how do i check the codes?
Jul 11, 2007 at 10:48 AM
MRTRDRVR
  • 20 POSTS
The connector on my 95 geo is actually just in front of the battery at the bottom center.
It has a rubber cover over it.
If you short the same ones as when you time the car then you need to run a wire between number 4 and 5 holes. Begin number one with the hole with nothing in it and count left to right.
Dale
Aug 22, 2007 at 6:04 AM
