[quote:a0d6b583e4="Windancer"]Where is the fuel filter on a 91 GEO Tracker ?[/quote:a0d6b583e4]
if you look under the back end, directly in front of your gas tank, it is mounted to the floor/frame towards the passenger side, look in front of the tank and you should be able to see it
Sep 11, 2007 at 4:16 AM
2CP-ARCHIVES
MEMBER
1991 Geo Tracker Where is the fuel filter on a 91 GEO Tracker ?
Apr 19, 2019 at 6:59 AM
(Merged)
2CP-ARCHIVES
MEMBER
If you look under the back end, directly in front of your gas tank, it is mounted to the floor/frame towards the passenger side, look in front of the tank and you should be able to see it
