Fuel filter location
WINDANCER
Where is the fuel filter on a 91 GEO Tracker ?
Sep 8, 2007 at 3:14 AM
JJONES88
  • 6 POSTS
[quote:a0d6b583e4="Windancer"]Where is the fuel filter on a 91 GEO Tracker ?[/quote:a0d6b583e4]
if you look under the back end, directly in front of your gas tank, it is mounted to the floor/frame towards the passenger side, look in front of the tank and you should be able to see it
Sep 11, 2007 at 4:16 AM
2CP-ARCHIVES
  • 4,540 POSTS
1991 Geo Tracker Where is the fuel filter on a 91 GEO Tracker ?
Apr 19, 2019 at 6:59 AM (Merged)
2CP-ARCHIVES
  • 4,540 POSTS
If you look under the back end, directly in front of your gas tank, it is mounted to the floor/frame towards the passenger side, look in front of the tank and you should be able to see it
