2004 Geo Tracker air conditioner clutch bearing
ALVIE KIZZIAH
Air Conditioning problem
2004 Geo Tracker 4 cyl Two Wheel Drive Automatic
how do you change the bearing inside the clutch.
also how do you pull the pulley
Sep 3, 2010 at 4:08 PM
  • 31,937 POSTS
Hi there,
There is a special puller required to remove the clutch hub, with it removed the bearing is usually held in with a cir clip.
mark (mhpautos)
Sep 3, 2010 at 9:44 PM
