1997 Geo Tracker troubleshooting
1997 GEO TRACKER
152,624 MILES • 4 CYL • 4WD • AUTOMATIC
JOSEPH1974
when gas pedal is pressed all the way open in drive or reverse the motor bogs down and it wont take off untill i get past 25mph then it kicks in ive changed the o2 sensor,fuel filter,converter,egr valve, mass air flow sensor,spark plugs,wires, fuel injecter cleaner any help would be greatly appriciated im broke n runnin out of options
Nov 1, 2010 at 10:42 AM
Check the fuel pressure and test the TPS and MAP sensors
Nov 1, 2010 at 11:20 AM
