1997 Geo Tracker Brake rotor bolts
LONIV
Brakes problem
1997 Geo Tracker Four Wheel Drive Automatic
I am having problems getting the stripped bolts off the rotor. Can you tell what to use to get them off?
Aug 24, 2009 at 12:31 PM
BLUELIGHTNIN6
  • 16,542 POSTS
If the head is stripped and a socket or wrench will no longer grip the bolt you can get a set of bolt extractors at any local auto parts store...they will dig into the bolt head so you can remove it.
Aug 24, 2009 at 2:36 PM
