1996 Geo Tracker car hesitates
160,000 MILES • 4 CYL • 4WD • AUTOMATIC
IVAN.CONDE
my geo hesitates when taking off like if wans't enough gas , but if i put it on 2 and then drive wil do just fine, is gota new egr valve,new maf sensor distribuitor cap and plugs
Jul 16, 2010 at 8:49 AM
  • 75,988 POSTS
Possibilities: Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
Jul 16, 2010 at 1:26 PM
IBUPROPHEN
  • 13 POSTS
Gee, this sounds more like a first gear issue in the transmission. How is the transmission fluid level? Does the fluid smell (yes i said smell) like it has a burnt smell to it? Is it real dark (black, brown, etc...)??? Maybe a clogged transmission filter (if equipped). Many diffrent scenarios here...
Jun 7, 2011 at 8:02 AM
