1996 Geo Tracker broken hose
200,000 MILES • 4 CYL • 2WD • MANUAL
VICTOPHER
There is a hose connected at part of the throttle body in between what I think are the EGR modulator and the EGR valve. The hose is broken in half and just leaks all the coolant out. I can't see it pictured in my Haynes manual so I don't know what to call it or where it connects to so I can replace it. Help...
I hope I've given enough info.... Thank you
Dec 24, 2008 at 4:01 AM
ZACKMAN
  • 4,202 POSTS
Your broken hose appears to be a heater hose (it leaks coolant, right?) EGR valve/solenoid has a vacuum hose, not coolant.
Can you post a picture of it?
Dec 27, 2008 at 4:55 PM
