1995 Geo Tracker will not accelerated
100,000 MILES • 4 CYL • 2WD • MANUAL
SPEEDSQUARE
car will not pick up speed on a hill incline what could be causing this problem
Mar 5, 2010 at 8:27 AM
  • 75,988 POSTS
Hesitation,chugging,lack of acceleration,bogging etc. could be caused by one of the following below.
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Mar 5, 2010 at 9:22 PM
