1995 Geo Tracker high idle during warm weather
CHRISMAPES
Engine Performance problem
1995 Geo Tracker 4 cyl Two Wheel Drive Manual
Its summer once again and my tracker which ussually operates flawlessly has began it high idle highjinx during warm weather. It did this last year as well. After much aggrevation and changing one part after another from a doner car, the problem was resolved. I did so much to the car last year, that I don't remember what it was that actually resolved the problem. Is there a common problem to this symptom, before I set fire to the whole thing.
May 15, 2009 at 2:19 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Check out Fast Idle Air Valve located on intake. Has a wax pellet, spring and plunger. Gets heat from water from cooling system. Pull off hot plunger must be seated if not replace.
Let me know
Thanks for donate
May 18, 2009 at 5:17 AM
