1995 Geo Tracker Exhaust fumes
1995 GEO TRACKER
124,000 MILES • 4 CYL • 4WD • MANUAL
MARYANN57
I have replaced the ecm this year & fuel regulator, now when I sart it up rough idle and heavy white smoke out the exhaust smell of gasoline,,,after car gets going most the problem stops?
Jan 1, 2010 at 11:46 AM
MICHAELDIAMANDIS
I have a 95 tracker that is doing almost the same thing. it runs ok until it gets hot and then the white smoke starts it runs rough and it also leaks fuel out of the cat.convertor. I changed wires, cap, engine temp sensor, ecm, coil. at my wits end. I don't think its a head gasket issue cause it doesn't smoke for the first 20 or so minutes. Have you fixed your problem yet and does my problem sound like what you have going on with yours?
Oct 5, 2012 at 6:18 AM
