1995 Geo Tracker 4WD
1995 GEO TRACKER
144,000 MILES • 4 CYL • 4WD • AUTOMATIC
TOD HAL
MANUAL FRONT HUBS LOCKED
4WD SHIFTER IN 4H OR 4L (SAME RESULT NO 4WD)
4WD LIGHT ON DASH ON
SHIFTING FROM REVERSE TO DRIVE (SAME RESULT)
NO GRINDING OR OTHER NOISES THAN NORMAL 2WD
Dec 27, 2008 at 10:39 AM
JNOVACK
  • 723 POSTS
so does 2wd work fine and only 4wd doesn't
Dec 27, 2008 at 12:06 PM
TOD HAL
YES ONLY 2WD WORKS (REAR WHEELS)
ONLY REAR WHEELS WORK WHEN IN 4L & 4H
U-JOINTS & DRIVELINE TO FRONT DIF.. ARE ATTACHED AND IN GOOD SHAPE ALSO
4WD WORKED FINE BEFORE I HAD THE ENGINE REPLACED .... I DON'T THINK THAT WOULD HAVE ANYTHING TO DO WITH IT THOUGH...
ARE THERE VACUUM LINES CONNECTED TO THIS PROBLEM ? PLEASE ADVISE
Dec 27, 2008 at 3:14 PM
JNOVACK
  • 723 POSTS
know for starters pull the shift lever put and make sure it isn't brocken if it is then we will have to go into the transfer case further let me know what you find
Dec 28, 2008 at 6:15 AM
