1994 Geo Tracker broken timing belt
215,000 MILES • 4 CYL • 4WD • MANUAL
TRACKERLOVER
broke timing belt driving on the interstate, replaced it and cam sproket, set timing. worked really well for a few days the started making noise in valve train area and lost power intermitingly. when power is ok timing shows good, when power is down the timing shows off...any suggestions
Oct 18, 2009 at 10:55 AM
BLUELIGHTNIN6
  • 16,542 POSTS
the 1994 tracker is equipped with an interference engine , meaning that when the timing belt breaks under operation the internal engine components (such as valves) will most likely be damaged. you need to inspect the engine internally for damage caused by the timing belt breaking.
Oct 18, 2009 at 11:46 AM
