1992 Geo Tracker fuel injector
CHAD4664
Electrical problem
1992 Geo Tracker 4 cyl Two Wheel Drive Manual
My 1992 GEO Tracker will not start. I am not getting fuel thru the injector. I am getting fuel to the injector but not thru the injector. I checked the fuses and they are ok. I also checked the resistance and got 1.6ohms. I also used a noid-lite tester on the injector and the light wouldn't light. I was told that their was no power to the injector. So i checked the voltage at the computer and injector and got 1.6 volts. Is that the correct voltage coming out of the computer. Does this mean that my computer, injector or my wiring is bad. thank you
Sep 30, 2010 at 1:29 PM
BLUELIGHTNIN6
  • 16,542 POSTS
volts should be 12 , not gonna run with just 1.6 volts, cuplrit is most likely going to be the computer itself
Sep 30, 2010 at 1:38 PM
